2/20/2015 3:07 PM | |
Joined: 5/29/2013 Last visit: 2/28/2025 Posts: 101 Rating:
i don't had that before, What is your status on TC_CON, SEND and RECV on the moment you can't receive anymore? Did you check the status in the helpfile of the functions or in the manual ? If you can't find the problem you could try to resend the SMS settings to the CP with TC_CONF. probably it does some kind of reset. but it depends on the status if it resolves your problem. |
