12/10/2021 11:54 AM | |
Joined: 12/15/2016 Last visit: 11/30/2023 Posts: 34 Rating:
Hello, I am trying to restore the IOT2050 to factory state. I followed the steps to burn the image to the MMC and enter the following command: mkfs.ext4 / dev / mmcblk1 The system indicates the following error: mke2fs 1.44.5 (15-Dec-2018) Found a back partition table in / dev / mmcblk1 Proceed anyway? (y, N) y / dev / mmcblk1 is apparently in use by the system; will not make a filesystem here! I tried to burn the image on a USB: done the following order: sudo fdisk -l I can see that I have 2 partitions on the USB, I attach image, and select the sda1 partition I do the installation command, but from USB: mkfs.ext4 / dev / sda1 I see the following: mke2fs 1.44.5 (15-Dec-2018) Found a gpt partition table in / dev / sda Proceed anyway? (y, N) y Creating filesystem with 3942400 4k blocks and 987360 inodes Filesystem UUID: 724e6e48-df01-47d2-9cfc-fb28e3d86175 Superbloack blackups stores on blocks: 32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 1605632, 2654208 Allocating group tables: done Writing inode tables: done Creating journal (16384 blocks): done Writing supoerblocks and filesystem accounting information: done and all remains the same, there has been no sign of recovery What am I doing wrong or how can I fix the IOT2050? Thank you so much, Edu ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/13/2021 12:00:02New subject after splitting |
12/13/2021 3:22 PM | |
Hello, Attached is a video so you can see the LED's turn on times between Status, read on the USB flash drive and screen. At the end, the screen shows me inserting the password of the Linux user who has booted into the eMMC. Let's see if you're lucky and you can see something. Thank you so much, Edu
Attachment2021-12-13.mov (241 Downloads) |
