1/10/2006 1:30 PM | |
Joined: 8/31/2005 Last visit: 5/17/2023 Posts: 217 Rating:
Hi all! The retentivity behavior of S7 controllers with MMC or without is different. For S7 controllers with MMC DBs are retentive by default. But you can set the retentive behavior for a DB in the properties of the DB (see manual CPU 31xC and CPU 31x, chapter 4.1.3). For controllers without MMC see the manual SIMATIC PLC S7-300, CPU Specifications CPU 312 IFM to CPU 318-2 DP, chapter 5. This FAQ may also be helpful: S7-300 - Declaring marker areas or data blocks as retentive |
Greetings, Chris |
