11/25/2008 1:39 PM | |
Posts: 2 Rating:
is it possible to use the 1SI module for RK512 communication? if yes.... what blocks are needed & what procedure to follow? |
11/25/2008 3:48 PM | |
Posts: 5822 Rating:
Dear Umya, as far as I know the 1SI does not support RK512 directly, but it supports ASCII and 3964(R). So if you insist on it you may have to program your own Stack. To see the differences check this FAQ out: Differences between protocols 3964(R) and RK 512 Best regards J_Bell |
