8/13/2010 9:50 AM | |||||
Joined: 3/21/2006 Last visit: 3/19/2025 Posts: 10239 Rating:
Hello, First you should assign IP address of S7-1200 CPU. One possible way is to follow this FAQ: How can you change the IP address of an S7-1200 PLC without STEP 7 Basic? The other possible ways are described into SIMATIC S7 S7-1200 Programmable controller manual. Then you should assign that will be use router -
