10/15/2012 11:31 AM | |
Posts: 3037 Rating:
Hello DavidBrown, Do you check if all modules using the function S7 routing? What are the requirements for using the S7 routing function and which modules can you implement? You can see more information about Routing in the following link. How do you use WinCC flexible to transfer a project to an operator panel via S7 routing? https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csSearch&objaction=cssearch&lang=en&siteid=cseus&query=&query2=WinCC%20flexible%20Routing&content=adsearch%2Fadsearch%2Easpx Tweety |
