5/18/2010 11:06 AM | |
Joined: 12/9/2009 Last visit: 4/18/2024 Posts: 156 Rating:
Hello, Do you have an seriell S7-300 or S7-400 CP to use the ASCII protocoll for communication to Metler Toledo???? I have found an articel in Service & Support Portal. It describes what should you watch out for when receiving data with ASCII drivers via serial S7-300/400 CPs: http://support.automation.siemens.com/WW/view/en/6894849 Perhaps it helps you. Good Luck Little Holmes |
