3/17/2016 4:04 PM | |
hi, I guess you need something like that: 6ES7340-1AH02-0AE0Siemens technical consulting/Engineering support can give you better solutions. RS 232 is a kind of point to point communication. Physically it has 3 wires. one to send (Tx), one to receive(Rx) and one ground(GRD/COM) Normally it is easy to establish. You have to set the same parameters on each side. you can see the parameters to set in the screenshot. hope this helps, regards,
