9/10/2011 1:58 AM | |
Joined: 5/28/2008 Last visit: 6/6/2023 Posts: 4448 Rating:
Hello, You can try to buy an interface cable fromProcess Informatikcompany. They have USB - S5 cable and I have tried it and it's easy to use. Hope this helps.
Ayman Elotaify |
9/13/2011 2:31 PM | |
Posts: 376 Rating:
Hello jm1983, If you use a PC with serial RS232 interfaceyou can take the PC converter cable with the order number 6ES5734-1BD20. The interface assignment of the PC converter cable finds you here: http://support.automation.siemens.com/WW/view/en/13063839 Here a further recommendation. I think this solution is better. Köster-Box (PC-S5-Interface) Interface for programming Siemens S5-PLCs with the PC. The Kösterbox converts the RS232 signals of the PC into TTY signals (20mA) of the automation system. • The box is full duplex, send- and recieve channel, • the box is active for programming S5 90-115U, • for S5-135/155U and CP or acting passively with other cable, • the box has its own power supply with galvanic separation Her the link:http://www.koester-systemtechnik.de/Koester_Box_E.html Best regards Azteke0110 |
9/13/2011 9:52 PM | |
Joined: 3/21/2006 Last visit: 4/12/2023 Posts: 10221 Rating:
Hello, Take a look there S5 programming cable Best regards, Hristo Mihalev |
9/14/2011 2:20 PM | |
Joined: 12/14/2010 Last visit: 5/25/2023 Posts: 160 Rating:
Thank you very much for your help UMENCHO. |
