6/26/2013 3:52 PM | |
Posts: 559 Rating:
Dear V4Friend, The cable you are using must be same as you have tested with Hyperterminal with IMC. For connection please find the attached copy of RS-232 Pin Description & 1SI module pin details. You just connect the cable to SI module as you have connected to PC for hyperterminal. |
6/26/2013 3:53 PM | |
Posts: 559 Rating:
Please find the wiring Pin Diagram of 1 SI module
AttachmentWiring_Diagram.pdf (101 Downloads) |
6/27/2013 9:15 AM | |
Posts: 559 Rating:
Dear V4Friend, Is there any update? Have you tested the same? |
