6/5/2013 9:10 AM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, I have done some testing on this isue, RS logic format is CSV, Tia format XLSX, first problem but easy to fix with Excell 2007. Attached file shows the results. There must be done a lot off copy/paste work to create a TIA file that you can import in your Tag-table without warnings or errors. Regards, Marcjan Attachmenttags.pdf (124 Downloads) |
Problem solved? |
6/5/2013 2:17 PM | |
Posts: 13 Rating:
Thanks Mate for your help |
