5/20/2019 10:56 AM | |
Joined: 6/8/2018 Last visit: 2/25/2024 Posts: 7 Rating:
Hello, I am running TIA PORTAL V15.1 and I am trying to simulate a KTP700 Basic. I am experiencing an issue when I configure the KTP700 version to V14.0.1.0 or higher (V15.0.0.0 or V15.1.0.0). Using these versions, the project compiles without errors but when RT Simulator launches, the window appears and it seems to bre freezed without loading the main image. If I change the KTP version to V14.0.0.0 when simulator starts everything works fine. Does anyone know what could be missing? Or has anyone experienced this yet? Please find under the ZIP file two images as follows: - TP700 Basic V14.0.0.0.png shows the simulator running OK -TP700 Basic V15.1.0.0 shows simulation freezed whithout loading main image. Thank you in advance. Best regards. AttachmentKTP700.zip (57 Downloads) |
5/20/2019 12:31 PM | |
Joined: 5/12/2006 Last visit: 4/22/2025 Posts: 22623 Rating:
Hi, after enable of 3D acceleration you must reinstall the virtual guest additions. Regards Christoph |
