1/26/2023 10:47 AM | |
Joined: 7/19/2022 Last visit: 2/7/2023 Posts: 97 Rating:
Hi SummerSeaSun, The number of tags in runtime that you need translates into all the variables that you use with connection to a PLC. Internal variables are not counted. So if you have 1000 tags in your project you will have to have a higher license and not the 150 tags license. Otherwise you will get a message indicating that you lack license and will go to demo mode.
