1/29/2019 7:11 PM | |
Posts: 3 Rating:
Hello :) Recently I have beeing working with the module CM1241 with a S7 1200. I have made the communication and I don´t have any errors, the problem is that when I try to send a value, it doesn´t change. I have put the adress 0 because send the values for all slaves that I have, and if I change the adress, BUSSY change to 1 like the PLC was searching an slave. I have tried change the adress for 2 or 4 but "bussy" is always 1 please Help!!! There are some pictures.
Attachmentpictures.pdf (120 Downloads) |
1/30/2019 9:14 AM | |
Posts: 3093 Rating:
Hello, How do you evaluate the status of system blocks in STEP 7 (TIA Portal)? Regards, |
2/11/2019 6:49 PM | |
Posts: 3 Rating:
Thanks a lot for your support. I have made the configuration and I can read and write registers. My computer can´t read and write so I put a router to help it and it was all, after that the router made it job all was working. |
