3/9/2018 2:35 AM | |
Joined: 9/27/2006 Last visit: 3/23/2025 Posts: 12344 Rating:
Hello Eric; I have not had the opportunity to work with REFLEX, so I am not able to answer all your questions. I hope these links can help you get an idea of what is involved in this system. Siemens will support the REFLEX system, since they purchased Ruggedcom in the past years. You will also find contact and support options from Ruggedcom in the second link below. The selector webpage also allows you to look into the different software and hardware options for REFLEX. http://www.h3isquared.com/system/files/Reflex%20Datasheet.pdf http://www.siemens.com/ruggedcom-selector Hope this helps, Daniel Chartier |
