6/29/2012 5:53 PM | |
Joined: 8/31/2005 Last visit: 8/20/2024 Posts: 2198 Rating: (328)
No you can't set a CPU to run by it's program. I case a several errors, like the lose of a PROFIBUS station the CPU calls the the coresponding error OB. If this does not exist in the CPU it stops. If you create a OB86 (even if empty) and download it, the CPU will not stop any more. Good programmers use the informations in the variables of the OB to check the reason and program a reaction if necessary. See chapter 1 of the System Software for S7-300/400 System and Standard Functions to find out waht OB you can use. In your case, use OB86 and OB122 |
