4/25/2012 8:39 AM | |
Joined: 8/16/2010 Last visit: 12/29/2022 Posts: 622 Rating:
How can I use cyclic interrupt on S7-1200 to run servo motor? Regards, Miloš |
4/25/2012 12:34 PM | |
Posts: 267 Rating:
Why do you want to use an interrupt? Is'nt your task assemble with the Motion control technolgy object? |
4/25/2012 1:14 PM | |
Joined: 9/23/2005 Last visit: 1/27/2023 Posts: 4176 Rating:
Hi, you can have a PWM by user program. There a sample program in /tf/WW/en/Posts/42960#top Take in account that the PWM will never run faster as your program and the time precision (rate on/off) will be dependent of the your user program time too. |
Denilson Pegaia |
4/25/2012 1:29 PM | |
Thanks,Pegaia. But, can you convert program to v11 of TIA, because I have some problem with converting. |
4/26/2012 8:49 PM | |
Joined: 2/16/2011 Last visit: 9/15/2022 Posts: 229 Rating:
Hello, What version of TIA are you using? Regards
Gabriel de Oliveira |
4/27/2012 11:36 AM | |
V11 SP2 with update 2 I already have problems with opening v10.5 projects...but not solved... |
