2/24/2022 2:31 AM | |
Joined: 2/24/2022 Last visit: 2/24/2022 Posts: 1 Rating:
Hello! I´m having a similar issue Run/Stop Led: Orange on Error Led: Orange/Red Flashing Maintenance: Orange on At first I was able to connect to the PLC, it had a TIA Portal 13 program, I couldn`t access the blocks so I tried a reset to erase the old program be able to work on it, and that when the issue started. I`m using TIA Portal 16 Were you able to solve your problem? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 02/24/2022 10:47:09New subject after splitting |
2/24/2022 11:33 AM | |
Joined: 8/6/2018 Last visit: 2/3/2023 Posts: 196 Rating:
hello, could you send us the diagnostic buffer? |
