6/3/2014 12:02 PM | |
Posts: 16 Rating:
Run-time error '429': ActiveX component can't create object
Attachment20140603_1343_16-.zip (326 Downloads) |
6/3/2014 2:16 PM | |
Joined: 8/27/2010 Last visit: 4/13/2024 Posts: 417 Rating:
Hi! Checkthislink. I cant be sure it helps, but the description of the problem look similar as per your video. |
6/4/2014 6:36 AM | |
Posts: 16 Rating:
http://youtu.be/6BycxddgFI8 |
6/5/2014 6:37 AM | |
Posts: 16 Rating:
Whysopcdaauto.dllhas no entries in the registry? |
6/5/2014 9:02 AM | |
I suggest you to use sysinternals, especially Process Explorer from the tools, which allows you to find out what files, registry keys and other objects processes have open, which DLLs they have loaded, and more. This uniquely powerful utility will even show you who owns each process. Here isa list of all sysinternal sutilities available (opens in new window). After you install it, check your .dll with Process Explorer and post a screnshot here. |
6/6/2014 9:48 AM | |
Posts: 16 Rating:
procexp |
