5/10/2008 10:41 AM | |
Posts: 177 Rating:
Hi, Is it possible to run the VNC application within a WinCC project, so that I can grant access to a remote machine? Regards, henno2000 |
5/13/2008 11:34 AM | |
Posts: 1776 Rating:
Hi, why don´t you use opc, or WinCC connectivity pack? What will you exatly do? |
5/14/2008 10:21 PM | |
Posts: 10 Rating:
Wedo that all the time here.... just install VNC server inside the WinCC Server and acess it throught a remote machine... |
5/16/2008 10:24 AM | |
Posts: 6 Rating:
Yes, you can install and run VNC in WinCC environment. I have been used this task and had no problems. |
