3/2/2011 3:39 AM | |
Posts: 10 Rating:
Hello Friend, I am trying to make a connection b/w PLC S7 200 CPU 224 and PC, using WINCC Flexible 2008 RT via cable PPI cable USB/PPI. In WINCC: I set a button to InvertBit Q0.0 when click Connectino Menu: Communication driver: Simatic S7 200, Online ON HMI devide: Baud rate: 9600, add: 1 Network: Profile: PPI In PG/PC: access point of application: S7ONLINE (STEP7) PC/PPI cable But when i run HMI program in Runtime mode: error 190011 occur: value could not be written to PLC Can you help me to fingure out what problem may i have, and any solution if it's possible. Thanks so much for your help $ 140003 Gerneral connetion Error while going onlineWinCC Flexible advanced 2007with S7-200. Attachmentscreen.zip (157 Downloads) |
3/2/2011 4:03 PM | |
Joined: 5/28/2008 Last visit: 12/8/2015 Posts: 901 Rating:
Hello Dinesh Ramanujam, the prblem depends on your connection. Maybe the following FAQ will help you... http://support.automation.siemens.com/WW/view/en/28263099 regards Manfred |
3/4/2011 4:06 PM | |
Joined: 11/14/2008 Last visit: 8/29/2022 Posts: 504 Rating:
Here maybe this will help . AttachmentWinCC Flexible HMI system alarms.pdf (934 Downloads) |
