5/21/2013 5:35 AM | |
Posts: 16 Rating:
Dear All, 1. AS414HAutomaticSystem 6ES7656-8CE33-1CF0; 2. BackupBatteries 6ES7971-OBA00 ; 3. DPAdapterConnector 6ES7972-0BB52-0XA0 ; 4. DPAdapterConnector 6ES7972-0BA52-0XA0 ; 5. DeepgrooveRail 6ES7195-1GG30-0XA0; 6. PROFIBUSInterfaceModule andDPAdapterConnectorOrderBag6ES7153-2AR03-0XA0; 7. DIModule 6ES7321-7BH01-0AB0 ; 8. DOModule 6ES7322-8BH10-0AB0; 9. AIModule 6ES7331-7NF00-0AB0; 10.AOModule 6ES7332-5HF00-0AB0; 11.DPCable 6XV1830-0EN20 ;
Thanks |
5/21/2013 7:45 AM | |
Joined: 5/6/2008 Last visit: 4/4/2025 Posts: 25 Rating:
Hi, for example for the 6ES7321-7BH01-0AB0 you can find the manual here: http://support.automation.siemens.com/WW/view/en/8859629/0/ru How can you recognize if there is an existing russian variant? 1. Take the order id and put it into the search on the top on the right side. 2. Click on the order id below "product links". You will see all information on the chosen product 3.Go th the register "Entries". 4. Selectbelow "Entry types" the entry "Manuals". 5. Select the relevant manual by clicking on the blue title. 6. At the end of the entry you can see "This entry is available in the following languages:". Click on more. 7. If there is a russian manual available you can select it. If there is no russian manual available, then there is no existing translation of the manual. If you have selected "Russian", the russian manual is displayed and can be downloaded. Good luck Maulwurf |
To explore the new Forum, you can follow the textbox in the right column, which will lead you to the corresponding page in the new Forum. Alternatively, you can start from the main page by following this link:
https://sieportal.siemens.com/en-ww/support/forum
In the coming days, we will update the configuration step by step, so that you are directed to the new Forum by default. The “classic Forum” will remain available for all known functionalities alongside the new one.
We are thrilled to finally share the future of our Forum with you. Thank you for your commitment!
Kind regards,
the Forum Support Team
