1/5/2015 5:13 PM | |
Posts: 8 Rating:
Ok, thx for help. But is there possibility of reading data from few s-7 1200 at the same time? |
1/8/2015 1:08 PM | |
Posts: 1368 Rating:
Hello, the easiest way (in my option) is the I-device functionality (using PROFINET) or the open communication ("normal"ethernet communication) with the T-blocks. Therefore, no configuration is needed. Every t-block is called with an unique connection ID, so you can call them more than once in your user program (how often,please look in technical data of CPU) and communicate with several S7-1200... There are many examples in the portal... for example http://support.automation.siemens.com/WW/view/de/40556214 |
