11/7/2005 2:10 PM | |
Posts: 25 Rating: (1) |
Friends, Is it possible to configure a tag to access the S-Flag's (S10.0) of S5 CPU either as bit,byte,word,Dword from WinCC V6.0. Regards, Demi. |
11/10/2005 10:34 AM | |
Posts: 3149 Rating: (171)
Hi Demi, S-Flags normally can´t be addressed by WinCC...
=>You shouldn´t use S-Flags Best regards, Nemo |
11/11/2005 4:45 AM | |
Hai, Thank's Salma and Nemo. I think I should do some modification in PLC by putting parallel bits to S-Flag. Regards Demi |
