1/15/2021 11:26 AM | |
Joined: 10/11/2006 Last visit: 1/31/2023 Posts: 5410 Rating:
Hello, for the DCC synchronism you need at least FW 5.1 and a DCB extension runtime license that is valid for the whole S120 drive: Additionally, an Engineering license for DCC is necessary. The license can be used after the synchronism project for other DCC projects again. Please have a look at the following applications example: |
With best regards, |
1/18/2021 10:02 AM | |
Hello, it would be possible with D410-2, too. The easiest way, depends on you experience with the different solutions. With Simotion you can use the axis FB. https://support.industry.siemens.com/cs/ww/en/view/48816191 |
