11/12/2014 12:33 PM | |
Joined: 10/11/2006 Last visit: 2/3/2023 Posts: 5412 Rating:
Hello mpavetic, with Sinamics S120 you have the possibility to add a so called Drive Control Chart (DCC)to your drive object. In the standard library you will find different blocks for performing calculations, logical operations etc. For example you can read in your actual speed into DCC, calculate a torque value depending on this speed and connect the output to the corresponding drive parameters. Here you will find a documentation for DCC: http://support.automation.siemens.com/WW/view/en/103497608 |
With best regards, |
11/13/2014 8:57 AM | |
Posts: 2 Rating:
I'm pretty much sure this is what I was looking for. Many thanks! |
