11/7/2018 3:48 PM | |
Joined: 12/13/2011 Last visit: 2/9/2022 Posts: 144 Rating:
Hi. https://cache.industry.siemens.com/dl/files/731/109741731/att_897052/v1/s71200_motion_control_function_manual_en-US_en-US.pdf Attachment1.pdf (282 Downloads) |
11/8/2018 12:41 PM | |
Posts: 2 Rating:
Hello, I also faced same problems and updating the S7-1200 to latest version fixed the problem. |
11/9/2018 1:08 PM | |
Posts: 2 Rating:
Hi, If you disable the checkbox you must make sure that the value of p1082 is same as in axis Configuration. Then this Solution is also fine. |
