5/17/2024 11:02 AM | |
Joined: 8/3/2009 Last visit: 1/24/2025 Posts: 14651 Rating: (1825)
Hello Wolky I´m not familiar with PCS7, is a S410 a S7-400H ? If yes, you can use the Unified Comfort Panel in the same way as a standard Comfort Panel: https://support.industry.siemens.com/cs/ww/en/view/96837136 The only difference is, that a Unified has no Value Change event of global tags, but you can use scheduled tasks for doing the same Bye Murof |
