6/11/2010 12:49 PM | |
Posts: 10 Rating: (0) |
Kindly tell the equivalent parameters when converting the S5-95U Closed Loop ControlPID Block SFB 201 / 202 into S7-300. Kindly help in this regard Thanks! |
6/11/2010 1:01 PM | |
Joined: 9/27/2006 Last visit: 10/3/2024 Posts: 12283 Rating: (2685)
Hello saad; The following FAQ might help you, "Converting control parameters from S5 to S7": http://support.automation.siemens.com/WW/view/en/17991108 It explains the different S5 PID parameters, their S7 equivalent (for FB41) and gives coversion calculations for them. Hope this helps, Daniel Chartier |
