8/7/2018 3:47 PM | |
Joined: 5/6/2010 Last visit: 6/1/2023 Posts: 1882 Rating:
Hello, you need the software "AuthorsW". When you start the software then can you administrate your authorization. What for interfaces do you have at your PC? For USB you can use e.g. cable USB-AS511 For Ethernet can you use e.g. adapter TCP-AS511
regards |
8/8/2018 7:02 AM | |
Posts: 13 Rating:
Hi CaOd Thank you for the guide. I tried to use AthorsW and performed offline transfer, but i am not able to find the authorization from the list for "STEP 5 BASIS V7.x). Regards Dechen |
