2/13/2012 1:09 AM | |
Joined: 10/7/2005 Last visit: 5/29/2023 Posts: 2965 Rating:
Hello ThomasRJ in addition to jklm's advice, check the program in the startup OB's (20, 21 and 22) and the Blocks thatare called from it for "G DB xyz" instructions. This instruction creates the DB's on PLC startup, so you would exclude these DB's from the EPROM. Should this instruction not be used, you'll need to change the program to utilise the already mentioned OB 254/255(do a search @ https://support.automation.siemens.comfor your CPU's part numberand you'll find its programming manual which has all the details on these OB's). I hope this helps |
Cheers |
