8/25/2009 10:25 AM | |
Joined: 7/17/2008 Last visit: 10/25/2013 Posts: 34 Rating:
Divyesh, You can find a step by step example for the commbetween S7 and CP1430 TF below http://support.automation.siemens.com/WW/view/en/22792412 About the WinCC You coulduse the channel S5 Ethernet layer 4, and then the 1413 , choosing 1413-1 or 1413-2 depends onif you use one or two CPs in the PC. Then you can fill up the 1413 channel properties (MAC and TSAPs) in the same way that the previous link. Hope this helps Regards |
