5/18/2020 3:27 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello with a Basic or Comfort Panel you will not be able to connect to a SQL Server!!! only with a PC Based HMI like WInCC Advanced RT for example: https://support.industry.siemens.com/cs/ww/en/view/61883659 Check out also this Topic: Bye Murof |
6/18/2020 8:04 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
New question published by valerossi46 is split to a separate thread with the subject Error 8602. Best regards |
