1/29/2013 10:39 AM | |
Joined: 9/23/2005 Last visit: 2/1/2023 Posts: 4177 Rating:
Hi, I suggest you create a Time Interrupt OB (for example 10ms) and inside of it read the values as IWxxxx:P, convert to float point and to the appropriate scale (see Sample program: SCALE and UNSCALE /tf/WW/en/Posts/31698#top), make the mathematical evaluation and send the value back as QWxxxx:P. If your want you can create the OB as SCL and use a "high level" program language for the calculation. |
1/29/2013 5:29 PM | |
Posts: 40 Rating:
Thanks a lot. |
1/30/2013 10:24 AM | |
you are wellcome |
Denilson Pegaia |
