2/12/2013 2:57 PM | |
Joined: 2/11/2013 Last visit: 10/26/2023 Posts: 21 Rating:
Thanks for your answer. For sending and receiving SMS, i will use AT commands, aright? |
2/12/2013 6:10 PM | |
Posts: 1547 Rating:
That's right. There's not really a standard for these, at best you can use: http://support.automation.siemens.com/WW/view/en/40616248 The block is not protected so you can do minor changes where necessary. |
2/12/2013 8:16 PM | |
Posts: 327 Rating:
Greetings It think you should be able, but you will have to use AT commands, and not the Siemens functions for sending mail. Best regards
7/7/2013 4:05 PM | |
Joined: 11/21/2007 Last visit: 3/16/2025 Posts: 2326 Rating:
Hello you can use CP 1242-7 Teleservice module ( https://support.automation.siemens.com/WW/view/en/6GK72427KX300XE0) for Sending / receiving SMS directly from S7-1200. This way you don't need AT commands and use the library provided. you can easily send SMSs to any mobile or another modem. This may be slightly more expensive than Serial Comm. module + Serial GSM Modem but much easier to program. Hope this helps Cheers Navnag |
Last edited by: Navnag at: 7/7/2013 4:06 PMThere is no such thing as the last bug in a program |
7/12/2013 9:22 AM | |
Joined: 4/24/2009 Last visit: 8/20/2024 Posts: 2682 Rating:
New question splitted to communication is lost Best regards O_Moderator |
