10/1/2014 7:53 AM | |
Joined: 3/20/2013 Last visit: 3/11/2025 Posts: 676 Rating:
there are 8 connections possible for the ethernet ports. That means: overall 8 connections. If you use them all for, let's say, S7-communication to other controllers than you are not able to connect to an HMI. your quantity structure sounds correct. |
Best Regards, |
10/1/2014 7:11 PM | |
Posts: 55 Rating:
Ok, thanks. That makes sense. 6 client + 1 server + 1 wincc connection, total of 8 connections. How about PG in this case? |
