6/6/2012 1:11 PM | |
Posts: 9 Rating:
https://www.automation.siemens.com/BR/tf/WW/en/Posts/57715#top |
6/6/2012 6:07 PM | |
Posts: 36 Rating:
Hello and thanks for your help but i had go through that example but it didnt work. please help me give some other example which explains every thing. |
6/20/2012 5:39 PM | |
Posts: 14 Rating:
Hello MINKU, I have the same problem. I use the same software but different CPU (1212C AC/DC/RLY, FW 2.0) When I looked on the online navgiation, I found an error which did not exist, looking at my program. I translated it from german. It reads "Block 'Data_Logging' was created with a newer version of STEP7. To open the Block an update of STEP7 is required." Do you have the same message? Maybe this helps you or somebody else to figure this out. I am at a loss. Kaisersosa AttachmentError message.zip (358 Downloads) |
6/28/2012 5:42 PM | |
Posts: 20 Rating:
Hi The EN input must be always ON The REQ input must be ON only when you want to create a new data log. |
4/10/2017 4:02 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4839 Rating:
New question published by kuet is split to a separate thread with the subject Problem with Data Logging Option when entering with IP Address. Best regards |
