11/26/2014 1:50 PM | |
Joined: 9/28/2012 Last visit: 11/9/2022 Posts: 75 Rating:
Hi Pegaia We are programming s7-1200 for datalogging where time is important, that it is the right time. Most of the time the customer is ordering like 5 datalog devices. But he will not install them within the 20 days you mentioned. The result is that the time is lost. question Is there an app solution that i can suggest to thecustomer so he can control it from his mobile. Offcours he then also needs a router with wifi to connect to thes7-1200. I found some apps but they all can not find the database due to the new structure. There is no offset mentioned anymore in the V13 software, if you create a new database. And these apps all work with offset. The datalog devices arenormally offline. hope you have a solution Laantje
11/27/2014 4:08 PM | |
Hi william Thanks that worked regards marc |
