10/29/2012 12:49 PM | |
Posts: 4 Rating:
Hello everybody, I using CPU 1214C DC/DC/DC and Version V11 SP2 Update 4. I have a problem with datalog.I try to make datalog and see it in the web server. Everything worked fine and I get nice results in csv file. But few days later I try to check results but I did get/see any results in the web server. I think the problem is in the datalog create block because when everything was fine I have a ID number. Now I get lways 16#0000_0000.Why????(as see in the attachments). Please can somebody help me Attachmentdatalog.zip (128 Downloads) |
8/17/2013 6:53 PM | |
Posts: 2 Rating:
Hello, I would like to ask if you found a solution to this problem. It happened to me the same thing. Thanks for the reply John
6/30/2014 7:51 PM | |
Posts: 6 Rating:
if you delet the CVS file and rescyle the power you will have new file created after the command is attactive |
