4/28/2014 9:21 AM | |
Posts: 1368 Rating:
Hello, with FW 1.0.1 up to FW2.0, there where many changes in the T-blocks done.So i would advice a fw update for the cpu V1 or use also a CPU V2. http://support.automation.siemens.com/WW/view/en/38710101 |
4/30/2014 1:17 PM | |
Posts: 1368 Rating:
Hello, please note: you can not update a CPU V1 to V2. For an update in general, you can use the "normal" S7-1200 MMC card or TIA portal. Information you find in the S7-1200 manual (chapter 14.6) http://support.automation.siemens.com/WW/view/de/36932465 Greetings As MMC Card you can use 6ES7954-8LB00-0AA0 6ES7954-8LF00-0AA0 |
5/16/2018 2:00 PM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
New question published by waheed is split to a separate thread with the subject CPU shows system fault after removing communication cable. Best regards |
