3/1/2016 1:44 PM | |
Joined: 2/18/2015 Last visit: 2/18/2025 Posts: 31 Rating:
Hi Im interested to make a Ethernet communication between a S7-1200 and a Festo CMMO-ST-C5-1-DIOP (Stepmotor controller).
But i found this "Control vi Ethernet 100002.pdf". AttachmentControl vi Ethernet 100002.pdf (639 Downloads) |
3/2/2016 1:52 PM | |
Joined: 4/28/2015 Last visit: 2/24/2025 Posts: 10832 Rating:
Hello, look pls at this and check parameters to your model: https://www.festo.com/cat/en-gb_gb/data/doc_ENGB/PDF/EN/CMMO-ST_EN.PDF model: xxxxxxxxxx DIO P Update: pls ask again Festo about this: This application note describes how to read the actual position and how to change the target position or velocity of position sets previously defined using FCT. It is an add-on to the description "Control via Ethernet (CVE)" in the manual of the motor controller CMMO-ST-C5-1-DIO. |
3/3/2016 12:07 PM | |
I have used the FCT software to config. the CMMO-ST. and used the Digital I/O too drive the stepmotor. Im intertesed to change values(pos, speed, acceleration.) in the positionlist from S7-1200 via ethernet. Festo replied: |
3/3/2016 12:56 PM | |
Ok, so you can try make it via that instructions as I said. |
With best regards... |
8/14/2018 4:08 PM | |
Joined: 8/25/2014 Last visit: 2/12/2025 Posts: 133 Rating:
Hello. Have you succeeded making the CVE communication to the CMMO controller? Cheers. Aleix |
