5/25/2012 5:34 PM | |
Joined: 9/8/2009 Last visit: 7/17/2023 Posts: 1410 Rating:
If you can't connect to printer using telnet, then I guess also PLC can't connect that's obvious. http://en.wikipedia.org/wiki/List_of_TCP_and_UDP_port_numbers As stated most ethernet printers (including Zebra) are accepting raw connection on their port no. 9100. Look in manual of printer which ports are accessible. Are you sure about IP address of printer? |
