5/23/2018 8:07 PM | |
Posts: 13 Rating:
Dear PioBzdrega, I think you are confused about the meaning of Real Time Communication, your S7-1200 used RT communication when it tried to establish connetion with your ET200s. Every profinet device used RT communications, by this way they communicated each other. I just found this post on PI, office switches dont handle communications the same way like industrial switches for Profinet communications. https://us.profinet.com/profinet-can-use-a-best-buy-ethernet-switch-really/ I think you have this issue because of the IO cycle time configured on your ET200S, your should have it at defaulf value 6 ms, because of this, your switch is not fast enough to forward packets to the PLC. You can see your IO Clycle time of your ET200s if you select it, go to Properties, PROFINET, Advanced Options, IO Cycle, Watchdog time. I understand that its cheaper to buy non industrial switches, but that dont guarantee that would work the same like a industrial switch. Regards, Online_Diagnostics |
2 thankful Users |
6/1/2018 5:01 PM | |
Joined: 12/12/2016 Last visit: 3/12/2025 Posts: 30 Rating:
We noticed that radio communication work quite week, by reason of noise. We could ping each siemens device, but bus fault blink all the time. We decide to change our access to network on the attachment picture , but nothing except faster response happend. After research on forums , we found this document : Industrial Network Concepts, which depict on the last page of profinet article. that we should change configuration of cisco 2960s used ports on : switchport access vlan 111 switchport mode access switchport voice vlan dot1p Surprisingly it work perfect, hope that it help somebody Best regards Piotr Bzdręga |
