5/19/2014 3:52 PM | |
Joined: 1/4/2007 Last visit: 9/22/2023 Posts: 1059 Rating:
Hello juha889, What do you mean with „converter, analog signal (volts)“? Normally load cells are connected directlyto a Siwarex module (=weighing module). Afterwards that Siwarex module is sending the current weight value to a PLC. That PLCcontrols a process (e.g. control a valve to fill a vessel). There exist several Siwarex modules for different applications. Take a look to: www.siwarex.com Best regards Siwarexi |
5/19/2014 4:15 PM | |
Joined: 4/11/2011 Last visit: 4/11/2023 Posts: 132 Rating:
There are plenty of converters/load cell amplifiers.One of them. |
I'm just a human. Mistakes are allowed. |
5/22/2014 8:01 AM | |
Posts: 4 Rating:
With 'converter' I meant the weighing module. We unfortunately don't have an option to use Siwarex right now :( With 'Analog signal (volts)' I meant that the weighing module sends 0-10V voltage to plc instead of current which is usually used. But for some reasons we have to use voltage this time. |
5/27/2014 2:52 PM | |
You are not right. Load cell cant produce millivolts itself (ifstrain gaugeload cells are used; more widespread). In principle it is aWheatstone bridge.
