7/5/2018 12:23 AM | |
Joined: 6/18/2014 Last visit: 8/6/2022 Posts: 4 Rating:
Hi, I would like to know about memory card using in s7-1214dc/dc. We can program it to use it in program mode. Manual is telling to make download to memory card. If you try to download from menu in project view you will find download but there isn't download to memory card. I am only think when I have been setting mode program to memory card is downloading primary to the card. I try to verify if I am right to take out memory card and insert it to USB card reader and this one add below project view in directory 'add user reader card'. When card is discovered by TIA and there are some 4 dirs I can open the one with block (function, db...) and I have found my last changes, means my download load the changes to memory card. Is there some more simple way how to verify the changes are on the card? Thanks a lot, JosephK ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 7/5/2018 10:12:41 AMNew subject after splitting |
