4/6/2017 12:04 PM | |
Joined: 1/23/2017 Last visit: 1/19/2023 Posts: 49 Rating:
Hello, I'm facing same situation. Have you solved it? |
4/7/2017 11:28 PM | |
Joined: 2/22/2016 Last visit: 3/19/2025 Posts: 142 Rating:
Hi alen23 and josepvr. I see that you allready have gotten remarkable help here. However I have a library that is build in the same way, as you decribe how you would have solve this. By exchanging the parameter of one mb_master block in a sequence. The library dosen't actualy change DATA_PTR parameter, but it had I nice way to work around the problem. To the DATA_PTR a array of bytes is connected. Then the deserialize function in TIA-portal is used to copy the content to the respective variable in each step in the sequence. I hope you might find this helpful. Take a look at: https://github.com/olab84/rexhip
