3/14/2018 5:34 PM | |
Joined: 5/29/2013 Last visit: 10/22/2024 Posts: 29 Rating:
Hello, I am having difficulties to change old Modbus blocks in the program to newer one. The only reason why I want to change is possibility to use QB_Start and QB_Count options in V3.0 blocks. In attachment you can see a working setup with 1214 DC/DC/DC PLC and not working setup with V3.0 blocks.. Could someone give advise where is the problem? AttachmentModbus problem description.pdf (369 Downloads) |
3/15/2018 2:39 PM | |
Could you actually show print screen of your working sequence? |
3/15/2018 2:54 PM | |
https://support.industry.siemens.com/cs/ww/en/view/47756141 Same result. 7000 + 8280 And SAME "sequence" recommended by Siemens (had to change RS485 port to match HW config) |
