2/19/2014 4:00 PM | |
Joined: 9/19/2011 Last visit: 12/12/2022 Posts: 134 Rating:
Use a signal board -- 6ES7222-1BD30-0XB0. The PTO/PWM can use these outputs. Larry |
2/19/2014 4:23 PM | |
Posts: 7 Rating:
Thank-you both for your replies. Is programming aPWM function as simple to do using a signal board as it is with a CPU that supports PWM? |
7/3/2017 12:31 PM | |
Joined: 6/19/2017 Last visit: 1/27/2023 Posts: 6401 Rating:
New question published by socaoh is split to a separate thread with the subject S7-1200 Pulse Output - System bit with time base 1 second. Best regards |
