1/9/2015 12:18 AM | |
Joined: 5/29/2013 Last visit: 2/28/2025 Posts: 101 Rating:
Yes huggy_d1 has the best solution to fill your needs :D But don’t forget that the Peek is standard Byte addressed, so multiply your Level with 2 when you’re going to use data type INT in your DB. And don’t forget to use a standard DB instead of the Optimized for your sounding Table. I made a demo project V13 (update 6) see attached. AttachmentSounding Table1.zip (352 Downloads) |
Regards |
