9/17/2010 10:47 AM | |
Joined: 11/26/2008 Last visit: 8/10/2022 Posts: 101 Rating:
The following links may be helpful to you: http://support.automation.siemens.com/WW/view/en/40616248- Wireless Signalling and Switching per SMS with S7-1200 controller (CE-X25) |
9/17/2010 3:37 PM | |
Posts: 21 Rating:
Hi, As the S7-1200 uses standard Ethernet connectivity, you can implement remote access via VPN (Virtual Private Network). You can find more info about this here: http://support.automation.siemens.com/WW/view/en/26662448 There is currently no specific Teleservice module available for the S7-1200. Hope this helps, |
9/20/2010 7:58 AM | |
Posts: 3 Rating:
Thanks Mr D for the links. There is a lot of information there !. I will check it. Thanks again |
